Gianlucam
Jan 13, 2019Tutor
ReadyNAS 312: after power outage drives seem empty
Hi. I've had a power outage and when power came back my ReadyNAS 312 was stuck on the "Connecting to the ReadyNAS Admin Page...".
I removed the 2 drives and restarted it to go into "safe mode", and...
Gianlucam
Jan 20, 2019Tutor
Thank you Sandshark both drives were corrupted (tried one at the time in read-only).
So I inserted only one and did an OS-reinstall and I got my data back! :)
I saved all my data to an external drive, and reformatted the drive in the NAS. and put the data back on it. All is good so far.
Now I want to add the second drive (that was there before power failure) as a *full redundancy drive* (not a parity drive), and I'm a little confused.
The first drive that's there (mounted and with data) says it's of type JBOD, but under the drive bay image it say it's in RAID-1, so which is it? JBOD or RAID-1? I thought JBOD and RAID-1 were 2 different RAID levels, so I can't understand how they can apply to the same drive.
So I inserted the second dirve (that was there before power failure) and removed any volume from it, but now I can't see how I can add this second drive as full redundancy drive.
There's the option to switch to X-RAID with this second drive (the X-RAID button on the right side of the web interfafe), but the popup warning message says that any new free drives will be used as expansion, which is not what I want. I don't want storage expansion, I want full-redundancy.
And on the left-side of the page it only gives me "add parity" or "add group" as options, but not add-as-full-redundancy.
How can I add this second drive as a full redundancy to the first drive?
Thanks,
-Gianluca.
Gianlucam
Jan 20, 2019Tutor
@Sandshark just to be clear, I'd like to add this second drive in a fully reduntant RAID-1 mode.
- GianlucamJan 20, 2019Tutor
I figured out that the "add parity" button doesn't actually add a disk which contains only parity bits, but it creates a redundant RAID-1 disk.
What a poor choice of verbiage for that button, and poor indications of what that button does.
I had to download the software manual and find the "Volume Operations Table" to figure out what that button does.
Very unclear user interface... :(I'm good now, the second drive is re-syncing.
Thanks,
-Gianluca.
- StephenBJan 21, 2019Guru - Experienced User
In general it is adding parity - RAID-1 being the only exception to that.
It could be worded as "adding redundancy" - that would be true for all RAID modes.
- SandsharkJan 21, 2019Sensei
I also don't aagree with Netgear's use of "JBOD". In my book "Just a Bunch Of Drives" means each is independently addressable. RAID-0 is all joined together as one with no redundancy. But I don't think Netgear is alone in their interpretation. I doubt whoever first coined the term is going to come forward and say who's right.
But, the end result is "All's good." You did what you wanted, even if it wasn't named as you expected.
