Gianlucam
Jan 13, 2019Tutor
ReadyNAS 312: after power outage drives seem empty
Hi. I've had a power outage and when power came back my ReadyNAS 312 was stuck on the "Connecting to the ReadyNAS Admin Page...".
I removed the 2 drives and restarted it to go into "safe mode", and...
Sandshark
Jan 21, 2019Sensei
I also don't aagree with Netgear's use of "JBOD". In my book "Just a Bunch Of Drives" means each is independently addressable. RAID-0 is all joined together as one with no redundancy. But I don't think Netgear is alone in their interpretation. I doubt whoever first coined the term is going to come forward and say who's right.
But, the end result is "All's good." You did what you wanted, even if it wasn't named as you expected.
Jan 22, 2019Guru - Experienced User
I use the term JBOD as you do.
But technically there are two ways to span disks with mdadm/flexraid. RAID-0 will of course to it (with striping, but no parity). But you can create two RAID groups (one for each disk) and concatenate them without striping. Unfortunately that is also commonly called JBOD, though I think a better term for it is "linear RAID".
