sfpegasus
Jan 24, 2017Tutor
ReadyNAS 312 ERROR System: Fan fan2 in enclosure Internal speed is below threshold
Ever since upgrade to 6.6.1 have been getting this error every week or so. Teltale sign is fan considerably louder than normal. System: Fan fan2 in enclosure Internal speed is below threshold ...
sfpegasus
Jan 25, 2017Tutor
As a followup, here's some of the log data. My suspicion is this is related to the antivirus, which I have disabled. for the time being. That seems to be the only thing that has changed over the past month or so with the OS update to 6.6.1 Wed Jan 25 2017 9:08:16 System: ReadyNASOS background service started. Wed Jan 25 2017 9:08:14 System: External storage device connected. Wed Jan 25 2017 9:07:04 System: The system is rebooting. Wed Jan 25 2017 9:04:15 System: Antivirus scanner definition file was updated to 57.22948. Wed Jan 25 2017 9:04:14 System: ReadyNASOS background service started. Wed Jan 25 2017 9:04:12 System: External storage device connected. Wed Jan 25 2017 9:03:00 System: The system is rebooting. Wed Jan 25 2017 8:58:49 System: Fan fan2 in enclosure Internal speed is below threshold. (0 rpm). Wed Jan 25 2017 8:58:11 System: ReadyNASOS background service started. Wed Jan 25 2017 8:58:04 System: External storage device connected. Wed Jan 25 2017 8:58:01 System: ReadyNASOS service or process was restarted. Wed Jan 25 2017 6:02:09 System: Antivirus scanner definition file was updated to 57.22947. Wed Jan 25 2017 6:01:03 System: ReadyNASOS background service started. Wed Jan 25 2017 6:01:02 System: External storage device connected. Tue Jan 24 2017 21:00:06 System: The system is shutting down. Tue Jan 24 2017 9:02:45 System: Antivirus scanner definition file was updated to 57.22942. Tue Jan 24 2017 9:02:43 System: ReadyNASOS background service started. Tue Jan 24 2017 9:02:41 System: External storage device connected. Tue Jan 24 2017 9:02:38 System: ReadyNASOS service or process was restarted. Tue Jan 24 2017 9:00:54 System: The system is shutting down. Tue Jan 24 2017 8:55:42 System: Fan fan2 in enclosure Internal speed is below threshold. (0 rpm). Tue Jan 24 2017 8:54:58 System: ReadyNASOS background service started. Tue Jan 24 2017 8:54:56 System: External storage device connected. Tue Jan 24 2017 8:54:53 System: ReadyNASOS service or process was restarted. Tue Jan 24 2017 8:53:35 System: ReadyNASOS service or process was restarted. Tue Jan 24 2017 8:53:08 System: ReadyNASOS service or process was restarted. Tue Jan 24 2017 6:01:11 System: Antivirus scanner definition file was updated to 57.22941.
JennC
Jan 25, 2017NETGEAR Employee Retired
Hello sfpegasus,
If you have important files stored to the ReadyNAS volume, please back up so you will not lose the data after factory reset.
