jason92s
Jul 09, 2015Aspirant
ReadyNAS 312 Need Help Understanding Snapshots
We're about to pull the trigger on a ReadyNAS 312 with either two 2TB or 4TB drives. We have about 290GB of data files. Ideally we'd like to have daily snapshots, but I'm unsure how much data a snapshot takes. If I go daily, does that mean each snapshot will have 290GB of data in it, and I'd get about 5 snapshots before pruning started? Thank you.
- BaJohnVirtuoso
Corrected as it was misleading.. I was using the English settings in general, not specifically the 'Settings' options in the GUI.mdgm wrote: The threshold is alterable using the shell not via the UI. - StephenBGuru - Experienced User
All snapshots are certainly visible. But I was talking specifically about what shows up on the "previous versions" right click, not about snapshots per se.BaJohn wrote:
ALL snapshots are visible, NOT just distinct versions.StephenB wrote: In your case, you'd see all versions captured in your hourly snapshots. (Not sure, but I think you won't see duplicates, just distinct versions).
I have double-checked this, and only distinct versions show up in "Previous versions". I have a share with 35 snapshots taken over the past three months. Files that haven't changed over that period come up with "no previous version found". Files that have changed don't give me 35 versions to choose from, only the ones that are actually different. All these files are in all 35 snapshots. - BaJohnVirtuoso
Thanks for clearing up the ambiguity.StephenB wrote: All snapshots are certainly visible. But I was talking specifically about what shows up on the "previous versions" right click, not about snapshots per se.
I wholeheartedly agree, and as I have mentioned elsewhere, hope none of the useful information in some of the posts is not lost in the transfer to a new forum.jason92s wrote: I can't tell you how helpful that is StephenB. Makes perfect sense and I think Netgear should append this to their KB articles. - StephenBGuru - Experienced UserI think "previous versions" is a very nice feature ReadyNAS feature, and perhaps under-publicized.
If you know what file you want to roll back, it is much faster/more convenient than browsing through a ton of snapshots.- CLHatchLuminary
If you know what file you want to roll back, it is much faster/more convenient than browsing through a ton of snapshots.Unfortunately, seems the "Previous Versions" feature has been changed in Windows 10 (or maybe in Windows 8, not sure). They now have you specify a location to "back up" to for the previous versions. So the snapshots are no longer available through the Windows Previous Versions feature.
- OOM-9NETGEAR ExpertI am not seeing that issue on my Windows 10 install.
Did you go into the share configuration on the ReadyNAS to enable the "Allow Snapshot Access"?
That button does two things:
1) mounts your snapshots to a folder so you can browse
2) allows the functionality for "Previous Versions" in windows.
- CLHatchLuminaryI'm thinking what I might do is keep it as is with offline access turned on, but set up a backup to my 4TB data drive on my PC as you suggested. We currently don't both edit files in that share, but it is good to know that she can still access the files if the NAS is rebooting, etc, and they'll sync back to it once it comes back online.
CLHatch wrote:
I'm thinking what I might do is keep it as is with offline access turned on, but set up a backup to my 4TB data drive on my PC as you suggested. We currently don't both edit files in that share, but it is good to know that she can still access the files if the NAS is rebooting, etc, and they'll sync back to it once it comes back online.Makes sense to me. I like that better than depending on offline access as a backup.
- CLHatchLuminary
StephenB wrote:
Got it backing up those important files to my desktop. I installed DeltaCopy on my desktop, and did a rsync backup using that... saw it complained about a long filename, did some googling, then updated the rsync, ssh, and libraries in the install folder to the latest from cygwgin to fix that. Thanks for the advice.
- Jun 06, 2017Retired_Member
