Andrew86
Aug 03, 2017Aspirant
Readynas 312 not starting up
This morning I found my readynas fan was at max speed and I could not access it at all. Either through shared or RAIDar. All the lights are on (power, backup lights) constantly. I have tried turning ...
Andrew86
I have just tried accessing the boot menu to do a memory test or boot as read only. I can get into the boot menu and make my selection with the backup button and lights, but pressing the reset button with a paperclip does nothing. I have tried pressing it briefly as I have done with past problems, and then tried pressing it for a second or two when that didn't work. Nothing.
Andrew86
Sorry, I should clarify that all the lights are lit up EXCEPT for the Activity light. I couldn't edit my first post.
- JennCAug 04, 2017NETGEAR Employee Retired
Hello Andrew86,
It may be time to contact support to see if there is something wrong with the chassis if you are not really able to get to the boot menu.
