Skaigh
Jan 04, 2018Aspirant
ReadyNAS 3138 has error message Bond interface bond0 has slave interface eth3 offline
After a firmware update to 6.9.0 I received and error message saying Bond interface bond0 has slave interface eth3 offline. I then updated the firmware to 6.9.1 but am still getting the same error ...
Marc_V
Jan 08, 2018NETGEAR Employee Retired
HI Skaigh
Welcome to the community!
Have you checked your physical connections? It should have been resolved through 6.9.1 update.
Kindly provide us a link to the full logs if possible. Many thanks!
Regards
- SkaighJan 10, 2018Aspirant
Hi Marc,
Thanks for reply. I have checked the physical connections and I think I have found the problem.
Someone had removed the eth 0 plug from the NAS drive! But becuase our server cabinate is on the wall, high up, it was very difficult to see.
I will check the logs again tomorrow just to ensure this has been resolved.
Many thanks
- Marc_VJan 10, 2018NETGEAR Employee Retired
Hi Skaigh
It should be resolved but it would be better to make sure that all connections are working.
Kindly let me know if it indeed is the cause of the problem.
Regards
- SkaighJan 12, 2018Aspirant
Hi All,
Yes problem solved. Not sure why the error message did not come up before the update as I guess the 4th ethernet cable had been unplugged for some time.
Many thanks for all your help. We are error message free!
