abeltran78
Jan 02, 2024Aspirant
ReadyNAS 3138 not accesible
Hello We have a problem with a READYNAS 3138 S/N: 4HMC91EM00033 The NAS remains inaccessible both by ping and by web navigator but the backups have been made correctly from NAS to NAS so in ...
abeltran78
Thank you StephenB
The problem that the NAS remains inaccesible has occurred 3 times in 2 weeks, forcing it shutdown with the power button and turning on again, makes accesible.
We are useing Windows with diferents navigators and ping to his IP Adress.
Raidair don´t detect the NAS and we have not tried to do ping to the hostname or ssh.
Jan 02, 2024Guru - Experienced User
I suggest downloading the log zip file the next time you reboot it.
- SandsharkJan 03, 2024Sensei
Are both Ethernet ports being used? If so, are they aggregated, or independent?
It is very odd that RAIDar won't detect the NAS and it is still performing backups. This suggests that something between the PC and the NAS but not between the two NAS is blocking the traffic.
- abeltran78Jan 04, 2024Aspirant
Hello
We have 4 LAN connected in Round-Robin, always work in this mode without problems since two weks ago.
We can to try to change the mode o configure with independents LAN with diferent IP every LAN to try?
- StephenBJan 04, 2024Guru - Experienced User
abeltran78 wrote:We have 4 LAN connected in Round-Robin, always work in this mode without problems since two weks ago.
I suggest just using one LAN connection, and see if that resolves it.
I have the logs but I don´t see any error
