david_spittle
Apr 21, 2018Tutor
Readynas 314 - No internet connection
Would someone mind helping me to get the internet working on my NAS? I don't tend to access it very often when I'm away from home so I'm not sure exactly when the problem began. I want it to work...
- Apr 22, 2018
Turns out my et0 had a gateway IP of 0.0.0.0, not sure how I managed to change that.
So it was a simple case of changing this to 192.168.1.1 and voila.
Thanks for the reply.
Dave
Marc_V
Apr 22, 2018NETGEAR Employee Retired
Since your locally connected devices have internet I assume that your devices are properly connected and getting the correct IP from your Ubiquiti Security Gateway which has 192.168.1.x
To get internet running on the NAS one of your NICs should have the same IP on your local Network.
Eth0 is set to Static which definitely needs to be set on the 192.168.1.x network and add the corresponding DNS server addresses.
Eth1 which is set to Dynamic but gets 192.168.0.1 which is not on the same network. Where is this connecting?
Since you can access the NAS Admin page can you set a Static IP address on your Eth0 or connect Eth1 and make sure it is getting a 192.168.1.x address. Use one NIC for now when connecting to the unmanaged switch. Also, please don't forget to assign a DNS server on the network settings of your chosen NIC (Google, Router address).
Again I know you have connected the units in the correct order (Modem>Router>Unmanaged Switch) since you have Internet on your other devices.
Hope this helps!
Regards
- david_spittleApr 22, 2018Tutor
Dave
