jhu23
Aug 20, 2018Aspirant
ReadyNAS 314 refuses all incoming SMB connections with "Access Denied"
I've got a ReadyNAS set up as a backup storage location for our server 2008R2 servers. I am looking to move from Rsync to Veeam, which means switching the way I connect to the NAS. I have set up a ne...
- Aug 22, 2018
Looking at the logs you just provided I noticed the server was connecting with IPV6. I disabled IPV6 on the server's NIC and the server can now connect with no issues. Thanks for your help!
jhu23
Aug 21, 2018Aspirant
Thanks for the reply - no the server has 0 mapped network drives. It does connect to the NAS via a program called Acrosync which uses rsync. Could that be the issue?
Edited to add that yes they are both on the same workgroup
Aug 22, 2018Guru - Experienced User
No, rsync doesn't use SMB sessions.
Assuming that your RN314 uses the default data name for it's volume, and you aren't using the default admin password...
Can you try mapping the NAS data volume to a drive letter with net use? For instance
net use * /delete
net use t: \\nas-ip-address\data /user:admin nas-admin-password
If you aren't familiar with these commands - be careful with the typing. The spaces and the slash directions matter.
