jhu23
Aug 20, 2018Aspirant
ReadyNAS 314 refuses all incoming SMB connections with "Access Denied"
I've got a ReadyNAS set up as a backup storage location for our server 2008R2 servers. I am looking to move from Rsync to Veeam, which means switching the way I connect to the NAS. I have set up a ne...
- Aug 22, 2018
Looking at the logs you just provided I noticed the server was connecting with IPV6. I disabled IPV6 on the server's NIC and the server can now connect with no issues. Thanks for your help!
jhu23
Aug 22, 2018Aspirant
Yep, I had tried that already unfortunately. Same result - Access Denied. Tried using my Veeam user as well as Admin. (Admin's password is not default)
mdgm-ntgr
Aug 22, 2018NETGEAR Employee Retired
Please send in your logs (see the Sending Logs link in my sig).
- jhu23Aug 22, 2018Aspirant
No worries, I've sent an email to the mod address with my zip file attached.
- mdgm-ntgrAug 22, 2018NETGEAR Employee Retired
You can see the failed login attempts in smbd.log.
You are running old firmware (6.7.5). You may wish to update the firmware and see if that helps. We are using a newer version of the samba package (used for the SMB server/client) in the current firmware so it would be good to rule out the issue being something addressed by a firmware update.
I see I can move to update 6.9.3, will it cause any config changes / downtime? I do not have physical access to the NAS, will it come back on its own?
