pingjockey
Mar 18, 2017Tutor
ReadyNAS 316 LCD/Touchpanel issues
So today I had an odd issue with my RN31600 in which the Netgear Logo and touch controller would remain lit up. Normally they would turn off after a few minutes but today they stayed lit for hours. A...
mdgm-ntgr
Apr 13, 2017NETGEAR Employee Retired
voidfunc please send in the logs for both units (see the Sending Logs link in my sig)
voidfunc
Apr 13, 2017Aspirant
Thank you for replying, mdgm.
I have sent the zips of the log files for both units (in the manner specified by the page linked to in your signature) with information about them in the e-mail body.
I wasn't sure if it is considered good community etiquette to also reply "in thread" after sending logs or not. I have replied so that the thread doesn't look abandoned, and I apologize if this is frowned upon or makes more "noise" for you.
Thanks again.
- StephenBApr 15, 2017Guru - Experienced User
It's fine to do that, and it can be helpful to keep the community informed on progress.
- voidfuncApr 21, 2017Aspirant
StephenB, thanks for the follow up on community etiquette. I'm glad to know I wasn't committing a faux pas.
Concerning the issue at hand, it turns out that it is not limited to the OS 6.7.0 unit after all. After a sufficient number of power cycles, the brand-new RN31600 unit running OS 6.6.0 has shown similar symptoms. There has been no significant change to the output of `dmesg` on the OS 6.6.0 unit, though, so the issues found in the log files for the 6.7.0 unit are most likely unrelated. (I'm still worried about them, of course, so I may start a separate thread about them.)
In addition to the "panel-LEDs-stuck-on-and-touch-panel-unresponsive" state that was seen on the 6.7.0 unit, sometimes the 6.6.0 unit will get itself into an "inverted" state. The touch panel works somewhat (the OK button is almost impossible to press at these times) but the panel LEDs function in a manner opposite to how they should. They stay lit at full brightness until you touch a button. When you touch a button, that LED goes dark. While you are touching the button, the LED behind the "Netgear" logo normally flashes on and off rapidly, too.
One other thing that I have observed on boots where the touch panel gets messed up is that right after turning on power to the unit, the LCD panel will often quickly display the "Shutting down...Goodbye" message. The LCD then blanks and displays the expected "Booting" message. I believe that this is due to the residual charge in the unit keeping the previous data "alive" in the touch panel hardware. My current working theory is that the touch panel hardware is not getting initialized properly on boot, and that this residual charge may contribute to (but is not the sole cause) of the touch panel/LED problems. As such, I've found that another useful workaround when the issue arises is to shut down the machine and remove any residual charge from it. A simple way to do this is to:
1. Gracefully shut down the unit via the web admin page or by pressing the power button on the front of the unit twice.
2. Locate the master power switch on the back of the unit, and flick it to the "off" ("0") position.
3. While the master switch is still off, press and hold down the power button on the front of the unit for 30 seconds (to be safe).
4. Flick the master power switch on the back of the unit to the "on" ("1") position. The unit will automatically begin booting.
On both machines, ALMOST every time this fixes the problem with one power-drain reboot. Only once, I had to do this procedure three times in a row on the OS 6.6.0 unit to bring it back to a fully normal state. Each time the touch panel got more responsive, progressing through the "inverted" state to normal working order. (This is one reason why I do not think that old data being held in place by the residual charge is the sole cause of the problem.)
Obviously there are still many unanswered questions, and I would love to hear any further input or ideas anyone may have. Admittedly, I may be completely off-base in my line of thinking, but hopefully this post will be of some help to others.- StephenBApr 21, 2017Guru - Experienced User
Has @mgdm followed up with you? If not, you might try a PM (using the messages link in the upper right).
