fatmonk
Feb 08, 2018Aspirant
ReadyNAS 316 touchpad freezing
I bought an RN31600 last year, and was randomly having a similar issue as the one described in this thread after using it for about half a month. The touchpad sometimes freezes and won't go off after...
Feb 09, 2018Guru - Experienced User
I suspect this is really a hardware failure. If you are the original purchaser (that is, the NAS is new, not used), you should contact support via my.netgear.com and request an RMA ("replace my defective Netgear product").
- Jan 17, 2024Retired_Member
