armybill
Apr 19, 2018Aspirant
Readynas 316 Volume is degraded (but all disks green)
So I have my system setup for X-Raid 5, Everythings been going good, but all of a sudden I have this volume degraded error. I have lost a disk before and it was pretty obvious that the disk had faile...
mdgm-ntgr
Apr 21, 2018NETGEAR Employee Retired
Do you see recent error count increases in smart_history.log?
Especially for the disk that's /dev/sdb (the disk may/may not show in disk_info.log)
- armybillApr 21, 2018Aspirant
In the smart history log I can actually see the old HD that failed and all the errors it had under uncorrectable errors and ATA errors
Under the HD that is shown as removed by the system, it has -1 for ioedc and 1 for cmd timeout, other than that its all 0s
In the Volume log all the errors are also at 0
- mdgm-ntgrApr 21, 2018NETGEAR Employee Retired
Check e.g. kernel.log or systemd-journal.log for messages about the disk that is marked as failed.
Sorry I should be clear, the failed disk I referenced in the previous message is a disk that failed had been replaced about a month ago.
As for the disk that is currently in the machine, but the mdstat log is showing as removed, there is no reference to it in the system journal and the kernal log is completely empty.
Its been running fine for about a month or so since I replaced the failed drive, than pow, this message comes up. The drive that failed was 4TB, I replaced it with a 12TB, and that is the drive that the system is showing as removed.
