MadManMike12
May 10, 2018Aspirant
ReadyNAS 3220 FW 6.9.3: Bond interface bond0 has slave interface eth0 offline.
Hi All,
We have a ReadyNAS 3220 running FW 6.9.3 (Just upgerade last week) and we are receiving errors in regards to the ether bond.
"Bond interface bond0 has slave interface eth0 offline."
evan2
May 16, 2018NETGEAR Expert
For bonding issue on 6.9.0, it only happen on RN312/314/316,
RN3220 didn't see the issue,
I see you update FW from 6.5.2 to 6.9.3, it has big kernel change.
I try to reproduce the issue, install 6.5.2 on RN3220 and run factory default, add eth0 and eth2 to bond0 (802.3ad LACP layer2),
then update to 6.9.3, but don't see the issue in my local,
Which switch are you using? Which bonding mode did you create?
Could you please delete bonding on your NAS and check if eth0 is offline after delete bonding?
