thedutchman
Dec 07, 2015Tutor
ReadyNAS 3220 Replacement disk offline
I have a ReadyNAS 3220, fully populated with 2TB disks. Recently, the disk in position 2x2 died. The RAID has been configured as RAID10, and had two hotspares. When the drive failed, the RAID trans...
thedutchman
Dec 08, 2015Tutor
OK, so I SSH'd into the NAS. The disk in question is sdb. Running "lshw -class disk" shows the disk, with no mount point and no partitions. Running "fdisk -l" shows the disk, but throws the warning message "Disk /dev/sdb doesn't contain a valid partition table."
So, do I need to create a GPT on it manually?
Dec 08, 2015Guru - Experienced User
Have you tried support?
- thedutchmanDec 08, 2015Tutor
Reseating the drive again seemed to solve the issue. I'm not sure why it would- the ReadyNAS saw the disk prior to reseating, it just didn't add it back to RAID until it was reseated. Perhaps it needed to be formatted (done in prior steps), and then reseated.
- StephenBDec 08, 2015Guru - Experienced User
I don't think that was it, but the important thing is that it is syncing now.
