thedutchman
Dec 07, 2015Tutor
ReadyNAS 3220 Replacement disk offline
I have a ReadyNAS 3220, fully populated with 2TB disks. Recently, the disk in position 2x2 died. The RAID has been configured as RAID10, and had two hotspares. When the drive failed, the RAID trans...
thedutchman
May 27, 2016Tutor
I've not selected an answer because this is still an issue. I have one disk that is offline. I've reseated it. I've reformatted it. I cannot add it back to the RAID10 as a hotspare. I cannot add it to the RAID10 as any sort of member. The ReadyNAS sees the disk, knows the make, model, firmware, location, etc. I'm not sure what to do with it at this point.
- JennCMay 28, 2016NETGEAR Employee Retired
Hello thedutchman,
It is best to contact support center for this concern.
