itops_jasper
Dec 01, 2015Aspirant
Readynas 4200 doesn't load OS
After loading the latest Radiator version 6.4.1, our RM 4200 unit won't boot anymore. On the console during boot, the last two messages are: Loading initrd.gz Ready Cannot find the unit on th...
JennC
Dec 02, 2015NETGEAR Employee Retired
Hello itops_jasper,
Your unit is a ReadyNAS 4200 which is one of the OS4 legacy units, may I ask if you what was the FW version this NAS was running on before you updated to 6.4.1? We want to know if you were already using an older OS6 version or the OS4 firmware.
itops_jasper
Dec 02, 2015Aspirant
It was running 4.2.23 before the upgrade. I didn't pay close attention to the release notes and assumed it's safe to load the OS6. If this is the cause of the problem on our 4200, is there a way to get the previous OS back ?
Best, -Itops
- kohdeeDec 02, 2015Administrator
Hi,
The ReadyNAS 4200 doesn't support upgrading from RAIDiator 4.2 to OS 6 natively. I'll find you some instructions for creating a USB Boot Recovery for RAIDiator 4.2
[edit] Here's instructions on how to setup the USB. http://home.bott.ca/webserver/?p=166 -- I'll have to work on getting something posted to the KB at a later time.
- itops_jasperDec 03, 2015Aspirant
Thanks very much. I will try this at my earliest convenience and report back to this post. Thx.
- itops_jasperDec 04, 2015Aspirant
Followed the instructions, but was unable to perform recovery. After BIOS/LUN check, the 4200 now responds: "MBR missing operating system". It's not clear if the USB drive is actually working, and I have tried 3 different ones so far. Any advice is appreciated.
Best, itops_jasper
