intraxict
Mar 22, 2017Aspirant
ReadyNAS 4312 - Volume Capacity for 12 x 8TB disks with RAID 6 & X-RAID
Hi all, Please point me in right direction if I have posted this in wrong category. This is my first post in this forum. I have done research about this but unfortunately I am unable to workour s...
- Apr 18, 2017
It's resyncing now. Once that completes volume expansion should then take place.
mdgm-ntgr
Apr 10, 2017NETGEAR Employee Retired
Any update?
intraxict
Apr 17, 2017Aspirant
I was on leave that is why couldn't reply earlier.
Please see requested:
admin@INTSMNAS1:~$ cat /proc/mdstat Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md127 : active raid6 sda3[0] sdf3[7](S) sdb3[10](S) sdg3[11](S) sdj3[9](S) sdi3[8](S) sde3[6] sdl3[5] sdk3[4] sdh3[3] sdd3[2] sdc3[1]
39045873920 blocks super 1.2 level 6, 64k chunk, algorithm 2 [7/7] [UUUUUUU]
md1 : active raid6 sda2[0] sdi2[11] sdf2[10] sdg2[9] sdb2[8] sdj2[7] sde2[6] sdl2[5] sdk2[4] sdh2[3] sdc2[2] sdd2[1]
5232640 blocks super 1.2 level 6, 512k chunk, algorithm 2 [12/12] [UUUUUUUUUUUU]
md0 : active raid1 sda1[0] sdf1[7] sdi1[8] sdj1[9] sdb1[10] sdg1[11] sde1[6] sdl1[5] sdk1[4] sdh1[3] sdd1[2] sdc1[1]
4190208 blocks super 1.2 [12/12] [UUUUUUUUUUUU]
unused devices: <none>
admin@INTSMNAS1:~$
I am new to this log so not sure if above is enough or not. Please let me know if you need more details.
Thanks.
- mdgm-ntgrApr 17, 2017NETGEAR Employee Retired
So as you can see 5 of the 12 disks in your data volume are marked as spare (S). In your case the data volume array is md127.
Can you send me your logs (see the Sending Logs link in my sig)?- intraxictApr 17, 2017Aspirant
Logs sent as per instruction.
Thanks in advance.
Is your backup up to date?
I can see your data volume is 100% fullYou shouldn't let your volume get that full. That probably explains why you've been having issues.
The expansion can be forced but I'd be much more comfortable with doing that if you have an up to date backup.
