AkashD
Jan 05, 2026Tutor
ReadyNAS 4312 | inactive Volumes
Hello! I am unable to access the drives / data on my Netgear ReadyNAS with 12 drives in RAID6 configuration with the following error in the UI: Initial Error observed in log: Volume: The volu...
Jan 05, 2026Guru - Experienced User
AkashD wrote:The volume data encountered an error and was made read-only. It is recommended to backup your data.
we have rebooted the NAS.
The right move would have been to back up the data. (and NOT reboot).
AkashD wrote:Remove inactive volumes to use the disk. Disk# 1,2,3,4,5,6,7,8,9,10,11,12.
Don't remove them, as that will result in data loss.
AkashD wrote:Warning in logs: Volume: Disk test failed on disk in channel 10, model WDC_WD101KFBX-68R56N0, serial 1DGPMKDZ.
There is something else wrong as well. Either the RAID array cannot assemble, or there is BTRFS file system corruption.
So download the log zip file - there is a lot more in that then there is on the logs page. If you have trouble sorting it out, you can send me the full zip in a PM and I'll take a look. You can't attach the zip, you need to upload it to cloud storage and include a link in the PM. Make sure the permissions are set so anyone with the link can download. Note you send a PM using the envelope icon in the upper right of the forum page.
