ArthurP
May 22, 2016Aspirant
ReadyNAS 516 and OS 6.5.0 slow to the point of unusable
this issue surfaced for me with OS 6.4. The workaround then was to turn off Virus checking and ultimately a firmware update. Now, with 6.5.0 the issue has returned. I am getting transfer rates of 3...
cmassey
May 22, 2016Guide
Out of interest what addon's are you running (if any) and have you made any changes or mods via SSH or other means?
How many drives are you running?
Is the speed issue there for both reading and writing?
I'm sure one or both of the netgear people above will help get it sorted but was just interested as I have a 516 and it is working fine with 6.5.0
- ArthurPMay 23, 2016Aspirant
The apps I run are Plex, Logitech Media Surver and the Netgear camera app (though I don't actually use the latter). This has been the state since I first set the NAS up. I have not gone into the NAS to do any customizations. It's all stock.
and, yes the speed issue is there for reading and writing.
- mdgm-ntgrMay 23, 2016NETGEAR Employee Retired
Looking at the logs I can't see an immediate obvious cause of this. 3 MB/s would sound like you are using Wireless G to connect to the NAS. How is your PC connected to your network?
- ArthurPMay 25, 2016Aspirant
I am using wireless AC. Speedtest.net shows my internet speed at roughly 50mbps up and down.
