fdebiasio's avatar
fdebiasio
ReadyNAS 516 self power on configuration
Hello, Yesterday I manually switched off the ReadyNAS: a maintenance work to the electric power was planned in the afternoon. My plan was to switch it on this morning, but the readynas was up and ru...
  • mdgm-ntgr's avatar
    mdgm-ntgr
    Mar 30, 2016
    Last state is the setting for ARM units, so the 516 wasn't affected by the bug that was fixed in 6.5.0 Beta 2.
    x86_64 units such as the 516 are set to POWER ON after a power failure. There isn't a way to override this except for the way StephenB mentioned.
ProSupport for Business
