chopin70
May 13, 2017Virtuoso
ReadyNAS 524X performance: encryption and transcode
I just got my new RN524X Here are the encrypted performance tests done on a single volume, no RAID protection, Seagate NAS 4 TB disk NAS performance tester 1.7 http://www.808.dk/?nastester
Ru...
- May 15, 2017
A bug in the forum locked this thread for sometime
I meanwhile opended another one:
So this one can be trashed / locked
May 13, 2017Guru - Experienced User
chopin70 wrote:
Any hints about the read performance ?
I am connected through a 1GB LAN not the 10GB LAN for now
Of course these speeds depend on the NAS, the network connection, and the client.
- Do you have another PC to test with?
- Do you have internet security or AV running on the PC
- Is the PC using an SSD? If not, what speed hard drive is it using?
- Are you using jumbo frames, or the normal 1500 byte ethernet MTU?
- Is ipv6 disabled on the NAS?
- chopin70May 13, 2017Virtuoso
Compression + Encrypted:
NAS performance tester 1.7 http://www.808.dk/?nastester Running warmup... Running a 1000MB file write on \\NAS-01\backup2 3 times... Iteration 1: 103.16 MB/sec Iteration 2: 85.80 MB/sec Iteration 3: 82.74 MB/sec ----------------------------- Average (W): 90.57 MB/sec ----------------------------- Running a 1000MB file read on \\NAS-01\backup2 3 times... Iteration 1: 89.20 MB/sec Iteration 2: 93.65 MB/sec Iteration 3: 89.56 MB/sec ----------------------------- Average (R): 90.81 MB/sec -----------------------------
There is little impact on write performance, so this also seems to benefit from CPU perfromances
The gain in read performance is probably due to the compression
- chopin70May 15, 2017Virtuoso
