bolter
May 26, 2022Aspirant
Readynas 6 ultra plus cannot log in.
My Readynas Will Not Let Me Login And Very Slow To Reboot. It Is Running OS6. I'm Wondering Wether I Can Remove The HDDs And Reset The Box Then Replace Them Back In, Keeping The Contents.
- Jun 05, 2022
Factory Reset Nas And Then Re-Installed OS 6.10.7 and Now All Is Good
bolter
I Have RAIDar Installed, But It Will Not Except My Password. I Can Access Most Of The Files Via Windows File Explorer, So Will Have To Find Enough HDDs To Take Files Off And Then Reset Box. Currently The Box Is Trying To Reboot And Is Stuck At 99% And Has Been For 2 Hours.
