jtrosky
May 18, 2018Star
ReadyNAS 6 Ultra Power Supply Replacement
I recently purchased a ReadyNAS Ultra 6 with (6) 2TB hard drives. The other day I started to get email notifications about the voltages (these were the last few before the unit said a drive was no longer present, then was present again and started a rebuild) - I shut the unit down after that:
| Wed May 16 2018 11:52:53 | System: V-12 voltage in enclosure Internal is out of spec. (-10.73 V). | |
| Wed May 16 2018 11:47:47 | System: V-12 voltage in enclosure Internal is out of spec. (-10.73 V). | |
| Wed May 16 2018 11:47:27 | System: V-12 voltage in enclosure Internal is out of spec. (-10.73 V). | |
| Wed May 16 2018 11:46:57 | System: V-12 voltage in enclosure Internal is out of spec. (-10.73 V). | |
| Wed May 16 2018 11:40:50 | System: V5_0 voltage in enclosure Internal is out of spec. (4.56 V). | |
| Wed May 16 2018 11:29:48 | System: V5_0 voltage in enclosure Internal is out of spec. (4.56 V). |
I was *really* surprised to find that Netgear doesn't (and never has) sold replacement power supplies! Do they really expect you to "toss" such an expensive piece of equipment because a $50 power supply fails???
Anyway, I started my search for a replacement power supply. The SeaSonic SS-300SFD is not very easy to find, so I ended up purchasing a "PowerMan IP-P300BN7-2" - wasn't even sure if it would work. I got the PowerMan power supply and found that it only has (2) power cables - each having (1) SATA power connection and (1) 4-Pin molex power connection. So I didn't have enough leads to simply cut off the ends and solder the original 90-degree molex connectors onto them (need 3 separate leads to do that). So, being desparate, I decided to just use what it had - I put a "2 to 1" adapter on one of the 4-pin molex power connectors, which gave me a total of (3) molex power connections.
Long story short - it works perfectly! No issues whatsoever. I even got the PowerMan power supply for $24.99. :-) It does *not* need a 24-pin extension like some have needed when using the SeaSonic SS-300SFD replacement. But you do need a 2-to-1 molex adapater. But still, for less than $30, I have a fully-functional ReadyNAS 6 ultimate again. :-)
Just an FYI in case anyone else runs into the same situation... I did eventually find a SeaSonic SS-300SFD and have it on order, to keep around as a spare, but the PowerMan seems to work great...
1 Reply
- JohnCM_SNETGEAR Employee Retired
Hi jtrosky,
Thank you for sharing your resolution and/or workaround. We appreciate your contribution to the community.
Feel free to post any suggestions, questions, recommendations or anything about your NAS that you think needs attention or will help others.
