mickle026
Aug 23, 2017Aspirant
ReadyNAS "Admin Page" is offline
Upgraded to firmware 6.7.5 through the web interface and now the unit is not responing via the browser at all. SMB share is still working Tried Rebooting Tried Reset via reset pin on back...
Aug 23, 2017Guru - Experienced User
mickle026 wrote:
If I factory reset it with different disks in it, can I the set it to x-raid and put back the original disks without losing data?
Will factory reset put the original firmware back in or will it use 6.7.5 ?
A factory reset installs the OS in the flash onto the disks. So doing a factory reset with 6.7.5 won't change anything.
You could try installing onto a scratch disk, and then upgrade the system to 6.8.0. Then power down, and insert the original disks in their original slots. When you power up, the system will try to upgrade the original disks to 6.8.0 - which might solve the problem.
If https://nas-ip-address/fwbroker reponds, then you could try installing 6.8.0 directly.
