btsixer
Jan 08, 2017Aspirant
ReadyNAS alert: Volume Warning - looks like a full root volume
I'm receiving ReadyNAS warnings stating: Less than 30% of volume media's capacity is free. NETGEAR recommends that you add capacity to maintain current performance levels. Continuous protection s...
mdgm-ntgr
Jan 08, 2017NETGEAR Employee Retired
If btsizer has checked btrfs.log and the data volume is less than 70% full then it could well be the root volume.
If it is the root volume it can be fixed using SSH. It's a matter of determining what's using lots of space of the root volume and then dealing with it appropriately.
btsixer
Howdy, details from btrfs.log and screenshots showing volume use attached.
BTRFS.LOG
Label: '43f664ec:root' uuid: ***
Total devices 1 FS bytes used 2.98GiB
devid 1 size 4.00GiB used 4.00GiB path /dev/md0
Label: '43f664ec:data' uuid: ***
Total devices 2 FS bytes used 6.76TiB
devid 1 size 4.53TiB used 4.29TiB path /dev/md127
devid 2 size 9.10TiB used 2.91TiB path /dev/md126
VOLUME CAPACITY
READYNAS ALERT
