btsixer
Jan 08, 2017Aspirant
ReadyNAS alert: Volume Warning - looks like a full root volume
I'm receiving ReadyNAS warnings stating: Less than 30% of volume media's capacity is free. NETGEAR recommends that you add capacity to maintain current performance levels. Continuous protection s...
vandermerwe
Jan 08, 2017Master
The message is referring to the data volume.
How much of the volume capacity are you using?
Are there any apps installed?
If it is a similar problem it'll probably require remote access.
mdgm-ntgr
Jan 08, 2017NETGEAR Employee Retired
That's very conclusive. You're using close to 3GB of the 4GB capacity of the root volume
