btsixer
Jan 08, 2017Aspirant
ReadyNAS alert: Volume Warning - looks like a full root volume
I'm receiving ReadyNAS warnings stating: Less than 30% of volume media's capacity is free. NETGEAR recommends that you add capacity to maintain current performance levels. Continuous protection s...
Jan 09, 2017Guru - Experienced User
mdgm wrote:
That's very conclusive. You're using close to 3GB of the 4GB capacity of the root volume
Plus the first data volume is also very full.
So there are two things to take care of.
btsixer
Jan 09, 2017Aspirant
Is there a utility I can run that allows me to care for disk utilization? Should I be attempting something along the lines of balancing data volumes?
I can do some searches for command line root cleanup but anything you can suggest would be helpful to get me started.
Thanks.
