btsixer
Jan 08, 2017Aspirant
ReadyNAS alert: Volume Warning - looks like a full root volume
I'm receiving ReadyNAS warnings stating: Less than 30% of volume media's capacity is free. NETGEAR recommends that you add capacity to maintain current performance levels. Continuous protection s...
btsixer
Jan 09, 2017Aspirant
Is there a utility I can run that allows me to care for disk utilization? Should I be attempting something along the lines of balancing data volumes?
I can do some searches for command line root cleanup but anything you can suggest would be helpful to get me started.
Thanks.
btsixer
Just found this KB:
Scrubbing
Defrag
Balancing
I'm going to back up the entire NAS and then take the storage offline and go through the process of cleaning everything up.
