Yeager44's avatar
Yeager44
Readynas Data Volume Full - Stuck booting at 99%
Hello,
My data volume /data is full and my Readynas 516 is stuck booting at 99% (Status: System starting up).  Is there a way to get past this so I can free up some space?  I've looked at previous posts and can't seem to find a solution to get to a point where the volume can be mounted.  Thanks very much in advance for any assistance you can provide.  :-)
  • StephenB's avatar
    One option is to use paid support (my.netgear.com).  You'd boot the NAS in tech support mode, and they can fix it remotely.  Note that If you purchased between 1 June 2014 and 31 May 2016, then you have lifetime chat support.
    Do you know the status of the OS partition? If so, is it full also?
    • Yeager44's avatar
      Yeager44
      Hello,
      Thanks a bunch for your quick response.  I can SSH into the NAS no problem, just can get to the web console.  I purchased my NAS in April of 2014.  I would definitely be willing to pay for support if thats the only option?  Thanks again for your help.
      • Yeager44's avatar
        Yeager44
        Sorry meant to say I can't get to the web console.  I can SSH into the box though.
ProSupport for Business
