bazbrian1
Jul 16, 2011Aspirant
ReadyNAS Duo - DLNA - Panasonic BWT700GL
I have a Netgear ReadyNAS Duo 2000 firmware 4.1.7 that has DLNA turned on. I'm looking at the Panasonic DMR-BWT700GL as a new HDD Recorder. http://www.panasonic.com.au/Products/DVD+and+Blu-ray/Blu-ray...
bazbrian1
Jul 17, 2011Aspirant
Yes, the Panasonic DMR-BWT700GL can act as a server and client. A couple of less expensive ones are only servers. But if I'm to spend close to AUD1000, I'm trying to find out if it REALLY works OK.
Thanks for your answer.
