rev1
Dec 20, 2013Aspirant
ReadyNAS Duo - Drive 1 dead no matter which drive
I've had my Duo for several years. Recently, the drive 1 led continuously flashes and FrontView indicates dead or needs attention. I swapped the drive with a backup drive and something. then I put ...
vandermerwe
Dec 21, 2013Master
Do you have a backup?
Is your Duo a v1 or v2? See:
http://www.rnasguide.com/2012/01/09/how ... -or-nv-v2/
Don't continue to do what you have been doing until you have a backup of your data.
I'd suggest you wait for advice here, or, if the unit is under warranty, contact support.
Can you currently access your data?
What happened when you replaced disk one with the "backup" disk. Was this disk the same size as disk 2? Did the unit then resync the drives?
