joah
Feb 09, 2016Aspirant
ReadyNas DUO backup error - 'read only file system'
Hello community, I hope you can help me with an issue i'm having with my ReadyNAS Duo (v1) running Raidiator 4.1.14. At night it runs a backup job which copies a folder from a computer on the LAN...
- Feb 09, 2016
Hi joah,
Aside from trying StephenB and JennCs suggestions, if you will create a test share, can you tell us if you will experience the same read-only behavior?
Looking forward to your response.
Kind regards,
BrianL
NETGEAR Community Team
Feb 09, 2016Guru - Experienced User
I don't know what is causing it - but I am wondering if resetting the file ownership/permissions on the backup share solves it.
JennC
Feb 09, 2016NETGEAR Employee Retired
Hello joah,
Here's the article in case you need it:
http://kb.netgear.com/app/answers/detail/a_id/14682/~/resetting-permissions-on-raidiator-4
- mdgm-ntgrFeb 09, 2016NETGEAR Employee Retired
How full is the data volume on the NAS?
- joahFeb 09, 2016Aspirant
It says 73% full.
- BrianL2Feb 09, 2016NETGEAR Employee Retired
Hi joah,
Kind regards,
BrianL
