CantonDan
Mar 30, 2021Aspirant
ReadyNAS Duo Can't Be Accessed
I am unable to access my Netgear ReadyNAS Duo from File Explorer on a computer running Windows 10. When I go to the devices IP address to list shares, (http://192.168.1.5/shares/), the screen says I...
JohnCM_S
Mar 30, 2021NETGEAR Employee Retired
Hi CantonDan,
You should be able to access the NAS shares via file explorer by entering '\\<NAS IP address>'. This should be able to list the shares of the NAS.
In case that you are still not able to access the shares by doing that, there is a possibility that SMBv1 is disabled on your Windows 10 computer. You should be able to check if it is enabled by going to "Turn Windows Feature On or Off", then look for SMB 1.0/CIFS.
