CantonDan
Mar 30, 2021Aspirant
ReadyNAS Duo Can't Be Accessed
I am unable to access my Netgear ReadyNAS Duo from File Explorer on a computer running Windows 10. When I go to the devices IP address to list shares, (http://192.168.1.5/shares/), the screen says I...
Mar 30, 2021Guru - Experienced User
CantonDan wrote:
When I go to the devices IP address to list shares, (http://192.168.1.5/shares/), the screen says I have no shares, however the device has shares. Thoughts?????
You are ending up in the browser, but you haven't enabled http for any of your shares. That is why the share list is empty.
Be careful on the slash direction in file explorer. You want to use \\192.168.1.5. If you use the other slash, you will end up in the web browser.
Sandshark
Mar 30, 2021Sensei
Is this NAS new to you? If so, you likely also need to enable SMB1 in Windows10, as it is disabled by defualt now, but the Duo does not support anything newer.
