hander1
Dec 16, 2011Aspirant
Readynas Duo: Dead drive 1 - what are my options?
Drive 1 just reported as dead. Rebooted and running OK on drive 2. Is there anything I can do to check disk 1 before getting it replaced under warranty? If it isn't covered for some reason, would...
mdgm-ntgr
Dec 19, 2011NETGEAR Employee Retired
Well the drive most likely has problems. I would power down, remove the drive, connect it to a SATA port on your PC and check it as I suggested above.
