hander1
Dec 16, 2011Aspirant
Readynas Duo: Dead drive 1 - what are my options?
Drive 1 just reported as dead. Rebooted and running OK on drive 2. Is there anything I can do to check disk 1 before getting it replaced under warranty? If it isn't covered for some reason, would...
techman05
Dec 19, 2011Guide
Should be noted you will probably need to the do the disk test anyway if its like Segate's return policy . Seagate uses a code in their test to decide what to do with the disk and you can't return without putting something there.
All that's left after that is do I want to pay to get it fast?, or should I wait a week and ship it back myself? I ended up with the get it fast since it came with packaging materials and prepaid shipping.
