swsb22
Dec 21, 2014Aspirant
ReadyNas Duo dropping connection
Hi I've got a readyNas Duo which has been connected via ethernet to my network (Samsung TV and iMac) for a couple of years without any real issues. However, I bought a new TV which is connected via w...
vandermerwe
Dec 21, 2014Master
I don't think its firmware as yours is almost up to date. Some users' problems are related to use of very old firmware, that's why I asked.
I would check the TV network settings, preferably set up a static IP address, or at least a reserves dhcp address.
Is the wifi signal strong where the TV is situated?
It would be helpful of you could try an Ethernet connection to see if the problem goes away. Is the TV too big to move temporarily? Do you perhaps have some powerline adapters?
