UmbertoSartori
Dec 20, 2011Aspirant
ReadyNas Duo from 500gb to 4 tb
Good morning. I bought a ReadyNAs Duo containing one 500gb disk and, separately, two 2tb disks, WD Caviar Green. After installing the Duo on my network, I inserted one of the bigger disks in the free...
UmbertoSartori
Dec 21, 2011Aspirant
Update to 4.1.8 with only one disk was successful, but inserting the second disk and resetting did not correct the difference of available space between the disks.
I made that procedure leaving inside the bay the first disk, which was the one with low availability.
So I remade it takeing out the first disk and leaving the second, and after reset I hot inserted the first. After sync the two disks were finally pair.
Thank you so much, mdgm, have a nice day
Umberto.
P.S. My Ethernet card supports jumbo frames, may I ask you another advice? On the card configuration I must choose between various jumbo modality. 2/3/4/5/6/7 kb MTU, which one is correct?
Umberto.
