checkm8
Apr 24, 2014Aspirant
ReadyNAS Duo only boots with no drives
Model: ReadyNAS Duo RND2000 v2. 2 x Samsung HD103SJ (1000GB/7200rpm/32M) in mirror running without problem for 2-3yrs. I normally receive email notifications for weekly backups to an attached USB ...
Apr 26, 2014Guru - Experienced User
Is the USB drive the backup drive? Or was it disk 1 of the NAS in an enclosure?
The Duo may be unresponsive for a while after you start the factory install. My recollection also is that fans will run full speed for a while. I'd start again, and leave it running for about 2 hours and see if it completes.
Why did you do the full reset btw?
