checkm8
Apr 24, 2014Aspirant
ReadyNAS Duo only boots with no drives
Model: ReadyNAS Duo RND2000 v2. 2 x Samsung HD103SJ (1000GB/7200rpm/32M) in mirror running without problem for 2-3yrs. I normally receive email notifications for weekly backups to an attached USB ...
Apr 26, 2014Guru - Experienced User
the 1.95 GB partition on disk 1 is the OS partition. The 929.11 GB partition is the data partition. All appears normal there.
The format of disk 2 is also normal. The v1 duo uses hardware parity, and doesn't format the data partition.
You could have a failing power brick, or it could be a a failure in the chassis somewhere. Inadequate power could explain why the system can't stay booted though.
