nicolasg
Jul 19, 2017Aspirant
ReadyNas Duo really slow -- kswapd0 high
Hi Netgear community, My company has a ReadyNas Duo 102 (6.4.0) and we have several problems since few weeks. I "repaired" what I could but now I need your advices. Basically, the Nas became re...
Jul 19, 2017Guru - Experienced User
It's not a Duo (if you call it that, people here will reply as if it were a duo v1 or duo v2). It's just an RN102.
nicolasg wrote:
Using "top" command (ssh), I observe that the "kswapd0" is really using. It does not sound good to me.
What services do you have enabled? You might need to disable some of them to reduce the memory footprint.
It's also possible that your NAS is simply undersized. You have an entry-level home NAS. An RN422 is more suitable choice for business use.
- nicolasgJul 19, 2017Aspirant
Hi StephenB,
Thanks for your answer.
You are right. Not a Duo :)
Here are the active services : SMB, AFP, FTP, ReadyDLNA, UPnP, HTTP, HTTPS, SSH. No antivirus, no apps (I deleted the only apps we had). Hope it helps.
We have the Nas since more than 3 years and that is the first time we have these problems. Before changing model, every technical advice sounds good to me.
Regards.
