PeterJEB
Mar 15, 2017Aspirant
ReadyNAS Duo RND2000 not booting - no disks detected
My ReadyNAS Duo was working fine yesterday - as far as I know, both disks were OK. I beleive the firmware is up-to-date but has not changed recently. I copied a large number of photos onto it and a...
mdgm-ntgr
Mar 15, 2017NETGEAR Employee Retired
That LED pattern indicates "No Disks Detected". See ReadyNAS LED Patterns
This either suggests disk failure or an issue with the chassis of some kind. Both are possibilities.
If the problem is the chassis (not the disks) then this procedure may help: ReadyNAS: Migrating disks from RAIDiator to OS 6 (note there would be some costs involved).
PeterJEB
Mar 16, 2017Aspirant
Thanks, I did see that first url but didn't quite understand - it's easier if one scrolls the window over to read it all!
I'll take a look at the second one now.
