don000110
Jul 18, 2014Aspirant
ReadyNas Duo RND2110 V2 Power off after insert first disk
I acquired a ReadyNas Duo RND2110 V2. With no drives inserted the unit powers up ok and all leds flash. I can see the NAS on the Network with Raidar. I have a brand new WD Green 2TB WD20EZRX drive, ri...
Aug 01, 2014Guru - Experienced User
That's a bit odd. The WD20EFRX works with my duo v1 with no change in jumpers, and I haven't seen any posts here from people needing to force the transfer rate. I'm sure lots of other people are using the WD20EZRX in their v1 NAS.
You should upgrade the firmware - it's ancient, and might be the reason you had this problem.
BTW you do have a v1, no doubt about it.
