bjussab's avatar
bjussab
ReadyNAS Duo RND2120 v2 (v1) - stuck on system starting up RAIDar
 Hello everyone.
Hope someone can share some ideas and help me. I bought a ReadyNAS Duo in 2010/2011. I used it for a couple of years before it was left to sit on a shelf unused.
I recently started to attempt to use it again, but when I did that I realised I had set it to a static IP with the old home network and it was now unaccessible and required network settings change.I attempted to do the smaller reset (OS Install) and try and access the drive, sadly this did not work. I resulted to attempt using RAIDar with a direct connection to the ReadyNAS. RAIDar detected the device but it just sat at the status of system starting up.
I really need access to some data on the drive to I connected them up to a SATA caddy and used Linux Reader, I managed to successfully get my files of the drives. After getting my data backedup I decided maybe a Factory Reset would be the best solution. So I did the hold reset for 30 seconds and see the drive lights flash twice. I plugged the ReadyNAS Duo back into my router and attempted to start it up. I can see it listed in RAIDar but once again its sitting at system starting up.
I started this device roughly around 9 hours ago. Can anyone shed some light on the situation please
Many Thanks
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    The factory reset process will take some minutes.
    First there is the 10 minute countdown in which time you can abort the factory default before it does anything by powering down the system.
    You can end the countdown by opening RAIDar, clicking setup, choosing the RAID mode and confirming your choice.
    Once you've chosen the RAID mode or the 10 minute countdown expires the disks will be wiped, the OS installed and the volume created. This will take some minutes. If multiple disks are installed and you are using a redundant RAID level, a resync taking some hours will start too.
    • bjussab's avatar
      bjussab
      Hi mdgm,
      Thanks for your reply. I am aware the factory reset process takes sometime, Just can't do anything as the ReadyNAS Duo has been sitting on System Starting Up (as the status on RAIDar) for the last 9 hours, and there is not setup or any other button and does not let me do anything at all.
      I did turn it off after an hour of sitting at System Starting Up, before turning it back on and leaving it for 9 hours (while I slept as it was nighttime in the UK).
      Thank you
      • vandermerwe's avatar
        vandermerwe
        Master
        What disks do you have in the Duo?
        Can you redo a factory reset with a single, different, known good disk, in the unit.
        Test the 2 disks using a PC and vendor tools while they are out.
  • Oh didn't know that. Deleted the partition and inserted into the Duo. Saying syncing volume c now. Hope it goes well.
    Yes, x-raid is what want and set it to when the message was shown.
    Thanks
    • StephenB's avatar
      Deleting partitions is safe, that restores the drive to an unformatted state.  Creating new partitions/reformatting might result in seeing a corrupt root message (more likely if you insert drives with the NAS powered down).
      But since you are seeing the sync starting, the NAS is responding normally.
ProSupport for Business
