andyhogg19's avatar
andyhogg19
ReadyNAS Duo RND2150 v2 dim blue light and fan always on
I have seen many similar questions and tried the suggested fixes. Have done a firmware reinstall, but the blue light has moved from a slow pulse, to a dim blue light and the fan is running always on....
  • StephenB's avatar
    Jan 26, 2018
    wrote:
    Would appreciate some advice frome here. Can I presume the disk is the issue? Should I swap the OK disk into slot 1? Is that a test to see if the bay is the problem and not the disk? Or should I just go buy a disk from the compatibility list for this model?
    It is almost certainly the disk - likely the system tried to boot from it and failed.  I'd leave disk 2 as it is, and test disk 1 in a windows PC with vendor tools (lifeguard for westen digital, seatools for seagate).
    The HCL is long-neglected, so I'd ignore it.  A WDC Red or a Seagate Ironwolf are good choices for the duo.  The biggest disk your duo can use is 2 TB.
ProSupport for Business
