flamesong1
Nov 29, 2014Aspirant
ReadyNAS Duo suddenly very slow to copy
I'm not sure if this is a Mac issue or not and if it is, maybe it's just a problem with Yosemite. I don't really know when it started as I may have been copying smaller files without really noticin...
vandermerwe
Nov 29, 2014Master
One thing you can check is the fullness of the OS partition.
Ssh in and
Post the results. Doesn't sound like this is the problem though.
Are you referring to the problem you had with DLNA?
Ssh in and
df -h
df -i
