flamesong1
Nov 29, 2014Aspirant
ReadyNAS Duo suddenly very slow to copy
I'm not sure if this is a Mac issue or not and if it is, maybe it's just a problem with Yosemite. I don't really know when it started as I may have been copying smaller files without really noticin...
vandermerwe
Nov 29, 2014Master
It wasn't me, it was, unusually, mdgm.
To ssh in you need to install something like putty on your pc, run it and enter the ip address of the nas.
http://www.chiark.greenend.org.uk/~sgta ... nload.html
The login is root
The password is the same as your admin password.
edit: of course, you have a mac - see StephenB's post below
You must first check a direct connection to rule out a network issue
The login is root
