flamesong1
Nov 29, 2014Aspirant
ReadyNAS Duo suddenly very slow to copy
I'm not sure if this is a Mac issue or not and if it is, maybe it's just a problem with Yosemite. I don't really know when it started as I may have been copying smaller files without really noticin...
Dec 03, 2014Guru - Experienced User
Regrettably it was exactly the wrong thing to do.
flamesong wrote: No, I understood the procedure to download the logs was the means to determine if the log files were large.
When you download the logs, the NAS zips them into a file on the OS partition. If the OS partition is nearly full to start with, that can take it over the edge.
