flamesong1
Nov 29, 2014Aspirant
ReadyNAS Duo suddenly very slow to copy
I'm not sure if this is a Mac issue or not and if it is, maybe it's just a problem with Yosemite. I don't really know when it started as I may have been copying smaller files without really noticin...
vandermerwe
Dec 04, 2014Master
Well the reason you can't access Frontview now is probably that the OS has filled up when you downloaded the logs.
As for the resync, how long has it been going now?
You have a backup now I presume?
You could perhaps wait 48 hours, if there is no improvement I think there are 2 options, one is to do a factory default and restore data from a backup. The other is for someone to remotely try to fix this. I think you may be able to pay Netgear to do this, but the cost would likely be prohibitive if you have a backup.
